interprétation rapport vacgom polo
Posté: 01 Mar 13 10:44
Je viens de finir le diagnostic de ma polo, quelqu'un pourait il me le traduire de maniere plus compréhensible ?
Au passage, j'ai fait ce diagnostic car ma polo ne veux plus démarrer.
voila le rapport ?
VCDS-Lite Version: Release 1.0
Friday, 01 March 2013, 09:46:34:0
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,41,45,46,55,56
Address 15: Airbags Labels: 6N0-909-60x-VW2.LBL
Controller: 6N0 909 603 P
Component: AIRBAG VW2 V00
Coding: 00080
Shop #: WSC 05311
2 Faults Found:
00532 - Supply Voltage B+
06-10 - Signal too High - Intermittent
07-10 - Signal too Low - Intermittent
Address 25: Immobilizer
Controller: 1H0 953 257 B
Component: IMMO VWZ3Z0T0087792 V00
Coding: 02400
Shop #: WSC 00000
1 Fault Found:
01176 - Key
65-10 - Unauthorized - Intermittent
Address 41: Diesel Pump Labels: 028-906-125.LBL
Controller: 028 906 125 B
Component: Saugdiesel FIA V01
8 Faults Found:
01168 - Idle Speed Boost Valve (N177)
31-10 - Open or Short to Ground - Intermittent
01050 - Glow Plug Monitoring
01167 - Full Load Stop Valve (N194)
30-10 - Open or Short to Plus - Intermittent
01269 - Commencement of Injection Valve (N108)
01052 - Load Signal Potentiometer (G157)
01204 - Engine Temperature Sensor (G27)
01169 - Door Contact Switch Driver Side (F2)
29-00 - Short to Ground
01209 - Engine Speed Signal - Alternator Terminal W
03-00 - No Signal
End --------------------------------------------------------------------------------------------------
voila le rapport ?
Coding: 00080
Shop #: WSC 05311
2 Faults Found:
Coding: 02400
Shop #: WSC 00000
1 Fault Found:
01176 - Key
8 Faults Found:
03-00 - No Signal
