de Frà.V le 12 Oct 22 15:38
Il faut regarder en haut de cette page internet en dessous de Polo land et tu auras la réponse.
Frà.V
- Polo lover
de Redbull123 le 19 Jan 23 15:45
The sound you are hearing is air leaking across a damaged gasket or a warped sealing surface. With the throttle closed, or in deceleration mode, the manifold pressure is very low and if there is a leak anywhere in the induction system that should normally be sealed, you will hear the (very common) whistle.
Redbull123
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 24 invités
